AI agents are having a moment. Teams across functions are under pressure from every direction while the tech stack keeps expanding.
But there’s a growing problem beneath the buzz: many agents look impressive in a pilot, then quietly disappear from daily workflows as teams opt to go with what they know — reverting to old ways of working instead of truly integrating agents into their day-to-day.
The reason for the dropoff is rarely the AI model itself. More often, teams build an agent without designing the operational layer that makes an agent dependable in real-world scenarios. An agent needs more than a prompt. It needs context, structured knowledge, access to systems, memory, human feedback loops, and consistent training and source material to improve over time.
Without that foundation, even the most sophisticated agent will eventually fall down on the job.
What is an AI agent?
An AI agent is an autonomous or semi-autonomous system that executes tasks based on goals, rules, and real-time data. The most effective agents are increasingly proactive: that means they don’t just wait for prompts; they monitor signals, anticipate needs, and initiate the next best action inside a workflow. Think of them as digital teammates embedded directly inside your workflows. In practice, that might mean:
  • Monitoring campaign or operational performance signals
  • Spotting stalled work before it becomes a blocker
  • Drafting briefs from historical data
  • Updating CRM or project records after customer interactions
  • Coordinating calendars and follow-up tasks
  • Generating content drafts and routing them for approval
  • Surfacing insights from feedback, tickets, or surveys before someone asks
What makes an agent useful is not just its ability to generate text, but its ability to contribute from inside real workflows. The best agents combine business knowledge, structured data, external tools, and defined decision paths so they can move work forward reliably — and increasingly, proactively.
7 key steps for building AI agents right
1. Evaluate where your agent can add value
Teams often miss this step when unveiling any new technology. No tool can or should be expected to solve all problems. The team, including the AI agent, won't be successful with broad expectations or nonspecific outcomes. That's why it's best to start with a specific, high-value use case that solves a clear pain point.
The most successful early agents focus on work that is repetitive, high-volume, and easy to measure. Think: the one-page meeting prep doc you build before every call — pulling recent news, financials, and competitive positioning on whoever's across the table. Or the campaign brief that used to take a week — competitor research, positioning draft, visual concepts, all packaged into a deck. Or data analysis and benchmarking that never quite made it onto anyone's plate.
Look for places where your team is drowning in manual tasks they already know AI could accelerate. The best starting point is where AI can deliver the fastest, most visible win — reducing turnaround time, eliminating repetitive handoffs, or helping teams scale personalized work without adding headcount.
Just as importantly, start with a single agent before evolving into multi-agent systems. Small wins build trust. Once one workflow is stable, you can expand its capabilities or connect it with other specialized agents. In other words, don't boil the ocean.
2. Prepare your workflows and data
Think about how you would onboard a new hire. You don't hand them scattered notes, outdated documents, and inconsistent training from person to person, and still expect excellent work on day one. Agents need the same thoughtful preparation.
Update your documentation to reflect how things actually work today. Use direct language, break complex workflows into sequential steps, and make your business logic explicit — don't assume the agent will infer it. Then go beyond just giving the agent access to documents. Add the context you'd normally pass along verbally: the nuances, the exceptions, the "here's how we actually do this."
On the data side, organization matters more than volume. Clean fields, linked records, consistent naming conventions, and visible workflow stages give the agent what it needs to understand relationships, ownership, and state. Messy structures and inconsistent taxonomy will directly degrade performance.
In Airtable, this often means clean fields, linked records, clear naming conventions, and visible workflow stages. Structured data turns vague generations into operationally useful actions.
3. Give agents access to the right systems and tools
Even the best-prepared agent is limited if it can't reach the systems where work actually happens.
Start with a system of record — a single place like Airtable that centralizes your data and workflows for both humans and agents. Then connect the tools your team already depends on: your CRM, marketing automation platform, customer feedback tools. When data flows into one place, the agent has the full context it needs to act.
Access to write back matters as much as access to read. An agent that can only observe will only answer questions. An agent that can take action — routing issues, updating records, escalating exceptions — actually moves work forward for your team.
Before you connect anything, define what the agent is and isn't allowed to touch. Thoughtful AI integration means setting governance and permissions at the start, not retrofitting them later. The goal is giving the agent enough context to be useful, with enough guardrails to stay trustworthy.
4. Align on how much autonomy your agent should have
Some workflows require deterministic outputs — producing the exact result every single time — and mandatory review every time to ensure that that happens. Others may allow the agent to act independently, with humans only monitoring exceptions.
The right model for your business depends on risk. For example:
  • Customer-facing messaging may require full approval workflows
  • Content drafts may only need editorial spot checks
  • CRM updates may be automated with defined exception alerts
The critical piece is building clear approval workflows so humans know when to step in, what to review, and how to override the agent when needed.
Human oversight is not a limitation, it's what enables trust in the technology.
5. QA your agent’s work and provide feedback
You would never hire a team and never review their work. Agents should be managed the same way.
Define what success looks like before deployment. That might include:
  • Accuracy and quality scores
  • Turnaround time
  • Reduction in manual steps
  • Throughput gains
  • Downstream business outcomes like conversion or retention
Then, create a repeatable feedback mechanism.
A practical example from content creation: Claude drafts 10 blog posts, routes them into a system of record like Airtable for editorial review, and your team scores each one against a rubric for brand voice, SEO quality, and strategic alignment. The agent can then reference review notes, identify patterns, and improve future drafts. This visibility helps teams understand:
  • Where the agent performs well
  • Where it consistently struggles
  • Which edge cases cause failure
  • What new workflows or skills should be introduced
The feedback loop turns a one-off prompt into a continuously improving system.
6. Build a shared library of agent skills
Not every capability your agent needs should be rebuilt from scratch each time.
Agent skills are reusable, tested capabilities — summarization, classification, data enrichment, scheduling, escalation routing — that can be composed into new workflows as your use cases expand. Think of them like Lego blocks: once a skill is proven reliable, any team member can pull it into a new context instead of starting from zero.
The key word is shared. Individual contributors often develop strong prompts and instructions through trial and error, but that expertise tends to stay siloed. A shared library — organized by use case, owner, and last-tested date — turns individual wins into team infrastructure.
This is how agents scale beyond one workflow and one champion. When skills are documented, discoverable, and reusable, every team member builds on what's already working rather than reinventing it. That's when agents start to compound.
7. Give your agent more autonomy
As trust builds through repeated QA, strong feedback loops, and predictable performance, you can gradually give your agent more ownership over outcomes. This mirrors how human teammates grow: first with close review, then with broader responsibility, and eventually with clear decision rights.
Start by expanding the agent’s authority in low-risk workflows, like those simple skill tests above. Over time, well-trained agents can begin to take on more complex tasks. The goal is trusted autonomy, where humans and agents collaborate at the right level of control and the agent can increasingly take initiative when context suggests action is needed.
Build agents teams keep using
The difference between an agent that gets abandoned and one that becomes mission-critical is the system around it. When knowledge, data, workflows, approvals, and feedback all live in one operational layer, agents become faster, more scalable, and dramatically more trustworthy.
That’s where Airtable can serve as your agent system of record: the place where humans and agents share context, collaborate on work, manage approvals, and continuously improve performance together.
Build AI agents your team can actually trust
Frequently asked questions
Start with one specific workflow that is repetitive and measurable. Then prepare clear documentation, structured data, systems access, human approvals, and a QA loop so the agent can improve over time.
The 30 percent rule is a practical guideline suggesting AI should first target the 30 percent of work that is repetitive, high-volume, and rules-based enough to automate safely before expanding into more complex tasks.
Build an AI agent when you have a clear workflow bottleneck, enough structured knowledge and data to support reliable outputs, and a team ready to create feedback and approval workflows.
It depends on scope and AI agent builder you choose. A single workflow built on existing tools and structured systems can be surprisingly affordable — costs rise when data quality, integrations, and governance aren't already in place.
With Airtable, they are. That's what makes it cost-effective.
Reading document head…
